Originally posted by sotyphoon415
View Post
Oil change 2009 PCM EX343
Tigé Jedi
- Jul 2010
- 4302
- TN USA
You'd think i would write this down but it's either a TG30 or TG8A...I'm pretty sure it's the Tough Guard 8A.. I have the PCM 343 with externally mounted oil filter. If I remember right it's a GM engine block but a Ford threaded Oil mount hence the Fram8A. Buy both, one will obvisouly fit, return the other2010 Tige RZ2 "Fully Loaded" 650hrs
Surf Ballast & Enzo Bag - 1235 prop
You can all thank me later... This thing is BAD A$$... http://www.harborfreight.com/6-1-4-q...l#.UyHHvfldWSowww.1320diesel.com Home of the Fastest Diesels!
Tigé Jedi
- Jul 2010
- 4302
- TN USA
MityVac makes an air-driven version too. Very appropriate for commercial situations (like dealers and service shops) but for the average guy like me, the manual style does a great job!
Wickedcummins, that is the model I have. Its not worth its weight in scrap IMO. I dont think it has enough suction, plus it uses to much air to do just a little bit of work..constantly running my compressor etc. Have the compressor on for an hour sucks. Im thinking it does not work well since its a HF item, Id bet the name brand one prob work better.
got a friend whom uses this and says it works great never tried tho
http://www.northerntool.com/shop/too...FQ5qfgodRT4Aogwww.1320diesel.com Home of the Fastest Diesels!
