so today I was all excited to get on the dealers new 13 Z1. I was pumped to go behind a Z1 with the convex VX and the new interior. First off the interior/design is really nice and a nice improvement. The transom walk through on the Z1 is great and a nice option. The rear storage is a very cool idea and much nicer then the RZR. Unless Im missing something the wake surf behind the Z1 with pro ballast and convex VX is nothing to write home about. My RZR looks much better and has much better push then the Z1 with pro ballast and convex VX. I used Ragboys Ballast setup and then went from 10.5-12mph to find the right speed and we found taps at 3-4 with 11.0mph ended up being the cleanest setup. This boat had the EX 343 which is the same as my RZR and was so underpowered compared to what I am used to. Im trying to find out what prop was on this boat but it was so underpowered compared to my RZR. I want to go behind a Z1 with the 409 to see how it compares. Overall I hate to say it but I wasn't overly impressed and was so set on the Z1. We are doing another demo on monday to give it another go. The Z1 is very tippy like the RZR when you are at cruising speed on the water. Another thing I noticed about the Z1 with the 343 is it had a horrible drivetrain clunk from forward to reverse. My RZR is butter smooth, this thing was very rough. I also noticed that the throttle linkage and the neutral holder was very stiff and not as easy to position as my RZR. This may get better with break in, or it may not.
Initial impressions of 2013 Tige Z1 vs my RZR not impressed so far with the surf wake
The RZ2/22Ve hull surfs better then any other Tige hull to date, so it should surf great, unless they get to monkeying to much. Hopefully the RZ changes are top deck/cosmetic type changes.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostThe RZ2/22Ve hull surfs better then any other Tige hull to date, so it should surf great, unless they get to monkeying to much. Hopefully the RZ changes are top deck/cosmetic type changes.
I'm actually curious how big of a surf wave you need? You must be a professional if it has to be taller, because the z1 I have w/out a convex vx and no ballast filled was fine. I had 8 people in my boat and let it list to the port side . There are also 5 batteries on that side but the wave was at least 1 foot taller than the back of the boat! While I was riding it had plenty of push. I could only imagine the height if I filled up port side ballast
Originally posted by barry1me View Postso today I was all excited to get on the dealers new 13 Z1. I was pumped to go behind a Z1 with the convex VX and the new interior. First off the interior/design is really nice and a nice improvement. The transom walk through on the Z1 is great and a nice option. The rear storage is a very cool idea and much nicer then the RZR. Unless Im missing something the wake surf behind the Z1 with pro ballast and convex VX is nothing to write home about. My RZR looks much better and has much better push then the Z1 with pro ballast and convex VX. I used Ragboys Ballast setup and then went from 10.5-12mph to find the right speed and we found taps at 3-4 with 11.0mph ended up being the cleanest setup. This boat had the EX 343 which is the same as my RZR and was so underpowered compared to what I am used to. Im trying to find out what prop was on this boat but it was so underpowered compared to my RZR. I want to go behind a Z1 with the 409 to see how it compares. Overall I hate to say it but I wasn't overly impressed and was so set on the Z1. We are doing another demo on monday to give it another go. The Z1 is very tippy like the RZR when you are at cruising speed on the water. Another thing I noticed about the Z1 with the 343 is it had a horrible drivetrain clunk from forward to reverse. My RZR is butter smooth, this thing was very rough. I also noticed that the throttle linkage and the neutral holder was very stiff and not as easy to position as my RZR. This may get better with break in, or it may not.
100% agree with the throttle interface too.
Originally posted by ChrisBarnes05-12-84 View PostI'm actually curious how big of a surf wave you need? You must be a professional if it has to be taller, because the z1 I have w/out a convex vx and no ballast filled was fine. I had 8 people in my boat and let it list to the port side . There are also 5 batteries on that side but the wave was at least 1 foot taller than the back of the boat! While I was riding it had plenty of push. I could only imagine the height if I filled up port side ballast
Originally posted by Bogdog View PostI think you should try the Z1 without the VX, I think thats the problem. I have a new Z1 without the VX. I always thought that if you add another two feet to the hull then it goes without saying that you need a bigger load to build the wake. I have no problems with my wake and I'm 260lbs and surf goofy. I find it a little rampy when we dont have enough weight up front so I'm still tweaking. The one thing that does irritate me is the "tippy" feeling that you get when cruising. for that I set the taps to 3/4 and that seems to help a lot, that and the fact that the missus and both kids weight the same as me so we get some balance.
Originally posted by tommy1005 View PostG23 also weighs 1000-2000 pounds more than any Tige and drives like a barge2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
