I am looking to get a pair of Pro 80x's for my 2011 RZR ... I have the Pro 60's right now ... I looked to order them online at wet sounds and they only come in white ... what happened to the black!!??
WS Pro 80x Tower Speakers
Originally posted by chadsanchez View PostI am looking to get a pair of Pro 80x's for my 2011 RZR ... I have the Pro 60's right now ... I looked to order them online at wet sounds and they only come in white ... what happened to the black!!??Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chadsanchez View PostSo the Rev 8's are the same size as the Pro 60's? I had the Syn - 4 installed when I bought the boat since I knew I would end up with 4 tower speakers ... Should I go the Rev 8's or the Rev 10's? Is there any visual difference in the Pro's vs Rev's?Ain't no 1/2 steppin'
Here is a thread where we added a pair of Rev-8 along side a factory pair of Pro-60 powered by a Syn-4.
http://www.tigeowners.com/forum/show...ght=tige+owner
This owner wanted 4 speakers for the aesthetics. Even though I would normally say that the available 125 watts to each speaker from the Syn-4 is a bit light for an HLCD, this owner was after a surf setup as primary and a wake-range setup secondary. The Syn-4 allowed us to tune the Rev-8 with lower mid-bass then the Pro-60 for a fuller, more balanced sound, but it just wasnt as loud as it could be as both pair are capable of handling more power.
Unless a 4 pod setup for the looks of it is high on your list, I would seriously consider replacing the Pro 60 with a pair of Rev-10. If a 4 pod setup and reaching wake-board range is your goal, then I would consider a different amplifier setup, which would depend on what you choose for the 2nd pair.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
