Uh oh! Hope they get you going quickly! Good luck!
Picking up new RZ2 on Wed...need your expertise
Learn how to turn properly and dont powerturn.
http://wakeworld.com/news/feature/fr...powerturn.html
Originally posted by bja37 View PostCame home without my boat!
Had an issue with the ballast and the PCM 409.
Very disappointed. You would think that when you're spending that much $$$ that the boat would be tested to insure everything works properly prior to delivery.
I ended up with 6" of water in the bottom of the hull....took almost 10 minutes for it to drain out of the plug hole.
How pissed would you be?
That is dealer preparation unfortunately some aren't as thorough on it as others. Also new boats have issues when buying a new boat I expect truest 15-25 hours to usually have things come up guess many aren't the same and think it should be perfect. I have seen some of the boats coming out of factories from some big names not saying any but you'd be surprised as to how much work dealers do in the rigging process.
What was wrong with be PCM409? As mine runs flawless and have had a couple with this motor and they are torque monsters when set up properly. Secondly ballast filling? Let me guess front bow bag didn't fill?
Originally posted by Ohope View PostWhat was the matter with the PCM 409? I pick up my RZ2 next Friday would and like to know more on your issues.
I would recommend talking to your dealer about it. I was told there was info sent out over the past weekend to dealers.
Originally posted by rensink View PostThat is dealer preparation unfortunately some aren't as thorough on it as others. Also new boats have issues when buying a new boat I expect truest 15-25 hours to usually have things come up guess many aren't the same and think it should be perfect. I have seen some of the boats coming out of factories from some big names not saying any but you'd be surprised as to how much work dealers do in the rigging process.
Count me as one who expected it to be perfect.
Originally posted by bja37 View PostFront bag was only one that filled....and it filled completely. That being said the screen only said 50% full with it completely filled.
Count me as one who expected it to be perfect."Riding the Wake of Life"
PCM is shipping new exhaust manifold to my dealer for replacement.
Not Tige's fault there.
However, my dealer has found additional leaks in the ballast system. In my opinion, there is ABSOLUTELY no excuse for this. This should have been thoroughly checked and RE-CHECKED in Abilene prior to anyone signing off on the boat and shipping it to me, the customer.
For those of you that know more about these mechanically than I do, how concerned should I be about this engine issue moving forward? I'm certain the inside of engines and water don't make for a good couple. With this boat having been water tested weeks ago at Tige, then sitting there for several weeks before getting shipped...I would think there would have been some form of water or moisture in the engine...and that can't be good. I'm trying to remain as patient as possible, but I spent alot of money to not have a used boat with problems....not to mention having spent a lot of cash to upgrade to the 409!
What would you do in my shoes?
