Well as some may know I have had a problem with my throttle assembly and have now come to the conclusion that I want a new throttle lever and the knob that is on the throttle lever that holds the TAPS switch... Is this something I can get from tige? Or is this something that I cant replace?
Where can I buy Tige Throttle knob and lever
Originally posted by Utemachine View PostIs there not an online dealer to get parts from for our boats?
The TAPS pump is also a custom order, as are the rams.
The TAPS pump is a basically a V351 HPU from Bennett Marine that has one side eliminated.
I think a standard V351 pump will work by just plugging one side.
The rams, according to Bennett, are the same as a standard ram they sell, but custom ordered with a slightly shorter throw.
The throttle is a Morse MV-2 with the trim switch optional handle, but has been discontinued and Morse was bought by Teleflex.
A Teleflex MV-3 assembly may work.
A standard UP/DOWN trim switch can be mounted on the dash to replace the handle mounted switch.
Originally posted by R&T Babich View PostThere are, but I think for the older boats like mine the throttle handle with the TAPS switch was a custom order by TIGE.
