Swim Platform Ladder
    Ragboy,
    When you are wakesurfing, is your deck underwater? Or only when not moving. I am trying to figure out whether to mount dead center middle or on the starboard side, so that they can grab the side of the boat to help climb on? We mostly ride regular, no goofies except the occaional guest, they will have to suck it up if I decide to mount the ladder on the starboard side.
    kerlee
      The beginning of this video shows you what the deck is like while surfing. The top is NOT underwater, except the corner of mine, but I shortened mine a few inches, and also cut the corner in. But if you look, the center is not really in the water. My guess is that if you did the ladder in the center, it would not make anything worse. But just a guess.
      http://wake9.com/
        Originally posted by kerlee View Post
        Ragboy,
        kerlee
        Mount it in the dead center.
        BTW you cant just mount it to the swimstep. The fiberglass swimstep is basically two pieces. An upper and a lower piece.(its hollow in between) You need to cut away a section of the lower piece add your hardware and re-glass it.
        Bad decisions make good stories.
          Will this interfere with FAE?
            I don't think so.
            http://wake9.com/
              That probably depends on how deep your swim platform is. On an older boat like mine, it might. I'd have to measure how much room I have.
                It shouldnt on you boat. From the FAE's i have seen I think you should have plenty of clearance.
                The step I have is basically the same distance as the edge of the platform when extended.
                  Moving to the front of the boat.......I know MC has this option on some of there boats, does Tige have something similar??
                    No, I think part of the issue is that the bow on an RZ2 or RZ4 sits up higher than the MC pickleforks. IMHO, I'd rather not have the bow plow issue than a ladder up front.
                      i have a 2008 22ve and i don't have a handle on the back of the boat to help with getting back onto the platform. i had an older lady that had a little trouble getting in and i'm sure my grandparents couldn't do it. any suggestions on installing a handle?
                        Well, you are in luck... Ragboy also did one.
                        http://www.tigeowners.com/forum/showthread.php?t=4445
                          Yes, a few of us did it, makes a great help getting in.
                          http://www.tigeowners.com/forum/showthread.php?t=3973
                          http://wake9.com/
                            Platform ladders
                            Hi There! Great pictures! If someone are interested of th best Platform ladder available on the market, check that link: http://www.nauticexpo.com/boat-manuf...dder-1202.html. Make your choice.
