I have them, they fit fine. I can get them all the way full with no issues. We actually stack 2 of them on one side when surfing and can get the top one almost full even with the bottom one full.
Thanks Timmy. My main concern was the height, I wasn't sure if they ran into the seat backs/wall that is there.
Yeah, I think they might expand under the divider a little bit - it's been since Sept since I've used my boat so it's hard to remember I do remember that they are pretty much the perfect size for those lockers.
I have the factory ballast and the V drive sacs. It fits but it a bit cramped with the factory tank, I can not get them full full, without getting the carpet in the locker wet. I would guess, 85-90% full which is still good when you factor in the stock tank.
FYI- not confirmed but on the site someone said they weighed the V drive sacks and found them to be close to 500LBs each and not the stated 400LBs.
So either way there is a lot of weight in the locker space.
What's funny about the v-drive sacs, the box they came in says 550 lbs each but every website out there says 400lbs. Not sure if I have an old box or ?
Thats what I needed to know. 85-90% full is good enough for me.
Thanks guys.
Korgae, any update on the registration decals that I sent?
