not sure how to get a pic into the post but you can look at the diagrams in the galleries section
2002 20V Ballast Install Question
Originally posted by Timmy! View PostDid you already order the 2" thru hull and ball valve? If not, I think you are going way overkill for your system and can save some money by scaling that down to 1 1/4" or 1".
These guys claim that a 1 1/4 will support 5 Tsunami 1200's:
http://www.wakemakers.com/brass-ball...-1-4-inch.html
Originally posted by Timmy! View PostThese guys claim that a 1 1/4 will support 5 Tsunami 1200's:
http://www.wakemakers.com/brass-ball...-1-4-inch.htmlMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostI dont know about 5, I have no issues using 1-1/4" to feed 3, but the hard part is fitting the 1-1/8" threaded inlet of the T1200 pump to a 1-1/4" PVC manifold.
I guess I will use the idea I saw online the other day. I will use a bushing to take the 2" pipe to 1" pipe. 1" pipe will fit very snug in 1 1/4" hose and so will the 1 1/8" fitting on the Tsunami pump. This looked like it would work pretty good and they guy said he did not have any problems. Save money on those exspenive fittings.
Originally posted by bamaboy2006 View PostWhat kind are they? How much for them?
$5.00 Ea plus shipping.
Originally posted by bamaboy2006 View PostWell I figured out how to load a photo to my gallery but not how to get it in a post. Please help.
shazaam.Other than that, Mrs. Lincoln, how was the play?
Originally posted by bamaboy2006 View PostOk. Well here are the pictures of the setup. Please let me know if you see anything that needs to be changed.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostIn the first pic (the colored one) your c/v's need to be in the vent line between the "T" and the sac, not on the drain line. They need to be oriented so it allows air/water to purge out of the sac when filling, then close when the drain flow is applied from the other direction.
Originally posted by bamaboy2006 View PostThanks. If I go with the 2nd option will I still need check valves?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
