Not So Dripless
    Not So Dripless
    I have a dripless propellar shaft seal that is water tight when not under power but at 30mph spews water into the buldge causing the pump to come on every other minute. Is there any adjustment to tighten this type of seal up or am I having to replace it? Cheers
    Maybe there is something that will help you out in this prior thread?
    http://www.tigeowners.com/forum/show...ht=carbon+ring
      Mine did this and the bellows needed to be compressed more.
      Basically loosen the belows to where they are naturally, then compress by 1 inch. Stopped my leak and has worked great for over a year. I can email PSS instructions if anyone wants.
        If you adjust the seal, don't forget there are TWO set screws per hole on the stainless ring. The outermost set screws hold in the inner ones, and the inner ones hold the ring to the propshaft.
