1995 Tige 2002 fslm comp
    I have a 1995 Tige 2002 fslm comp. I’ve only had this boat for roughly a month. I took the boat out last weekend it started off great. While heading back to the ramp boat started going slower and slower, went off of plane and wouldn’t go over 10 mph. Replaced the water separator. Today it ran great for 5 mins then started doing the same thing again, now it won’t crank back. When I tried crank it at home (with water hose hooked up) A LOT of black soot came out of the exhaust. Anyone can help to point me in the right direction. Thank you!
    Pull a sample of fuel from the tank and see if you have trash or water. If carb, maybe time for a rebuild.
      The boat is fuel injected so no carb
